CB antenna hole cover Part Number?
KelleySpyder
Hi we have a 2016 RTL that had an XM antenna mounted over the hole on the left side. We took it off and need the cap that covers the hole. Does anyone know what it’s called in the BRP parts diagram or what the part number is? Our baby is Intense Red Pearlcoat.
If you go to CHEAPCYCLEPARTS , look for the fiche' that shows the rear " luggage ", that's where I looked and found it years ago ..... Mike :thumbup:
HI,
I found on the BRP parts Diagram the name of the cap that covers the covers the hole: it is CB or XM Radio Connector Cap Part Number: says Not Available Separately, CB Connector Cap part #is: 710 001 930. http://instructions.brp.com search by part name. part number 219400610.
Deanna
I covered both antenna holes on my 17rt by getting metal flags that measure about 2x3. They have double back tape which has held them on for 2 years now. There are many stores on eBay that sell all sorts of designs of metal badges.
Instead of plugging/ capping off -depending on size, maybe use as power port for heated gear? Just a thought
So, you’re looking for the color matching cap to completely plug the left hand hole, right?
Appears to be 708301413 Intense Red LH Cap
It’s a little easier to find on the 2015 luggages diagram ( item #131). It’s item #74 on the 2016 diagram but not as intuitive. Trick will be to find one that’s not a special order. eBay might have a couple.
YES!!!! Thank you!
