Cat Delete
donrokon
What are some helpful hints for mounting the cat-delete pipe springs, this is on late model RT? Already have done this before with the standard spring hook for motorcycles. There has to be an easier method than brute force.....LOL
right angle needle nose
I got a set of 14" very long needle nose pliers from harbor freight. One of them was a RIGHT angle at the end. I was able to hook the spring and able to pull straight back. A lot more pulling power. As for the other long needle nose I can't tell you how many times I used one or the other to retrieve a dropped screw from deep inside where fingers and smaller pliers cant reach.
tip: lift the rear of the cat delete and do the top spring first.
If there is the will there is a way.......
I used a HF spring hook but someone else on here used a length of parachute cord. They tied one end to the spring and the other to their foot then pulled the spring and hooked it up.
A TOOL I MADE
:agree: ....I had difficulty also ..... I made a tool from flat stock with a nail bent into a hook near the end ..... I used it as a lever to get the springs off & on ....... I can send pics to a smart phone ..... PM me if you want them ( with your # ) .... Mike :thumbup:
My Cat was really easy to remove and install. Scientific term "Kitty Deletes" was done by Lamont. Both of
them.
:joke: :D
​Jack
