Just installed the cat bypass and all went well. Here are a few things to note:
1. It helps to have someone who is automotive savvy do the install. My son-in-law does his own car maintenance and has a good set of tools. Made the job a lot easier.
2. I would read and print out all the past cat bypass comments. There are a lot of good suggestions that will make the install go easier.
3. I bought a pipe expander (too small) and ended up bending the pipe edges with a cresant wrench.
4. We used a floor jack to raise the bike up and a small jack from my car to position the bypass.
5. I bought a headlight spring tool to take off and put back on the pipe spring. This tool was very useful.
6. When working with the spring it can come off and end up in the surrounding panel. Use a magnet tool to retrieve it.
7. Using lithium grease on the inside of the bypass pipes was very helpful.
8. The install time took a little over two hours. Fired up the spyder and she sounds great. Looking forward to a little more performance out of the 998 and a lot less heat in the passenger area.
