Cargo trailer.
james36il2000
I have spotted a post on here before I got my
spyder, but what size of inclosed cargo trailer that a 2014 rt limited will fit in and transport if need to be. I have an single axle 6 by 10 inclosed, didn't know if it would fit or not, or it has to be a bigger size yet, haven't done any measuring yet, just didn't know if anyone knew. Thanks
Sent from my SM-N910V using Tapatalk
The problems with 6X10 enclosed.
If you have a ramp door. Is the distance between the lift cables greater than 62 inch for the 61 inch Spyder to squeeeeeeze through.
Is the distance between the door jams greater than 62 inch. Same reason as previous.
The 10 foot length is not long enough for tie downs through wheels as recommended by BRP. Will have to use a wheel chock system.
Thanks Billy for the quick response, yes it has a ramp door, I'm not where the trailer is, but I will measure, I got a feeling it will be a very tight squeeze if I can even make it work. Man it would be nice if it did. Plus I didn't know if the spyder was to heavy for the ramp it self, I'm a musician and I have band gear in it right now.
I have used my 6'6"X10' landscape trailer to haul my Spyder. It can be done. I just picked up a 7'x12' enclosed trailer to do that job now. Spyder fits with room to spare. :thumbup: Tom :spyder:
