Carbon Fiber Handle Bar
frank3
RT-S PE#0180
Finally got the parts back from the painter and reinstalled the handle bar. Looks so much better than the bare aluminum. Next phase is the rear drive/timming belt pulley. My painter is on vacation till after the 1st so this will take longer. With the rear pulley done, I won't have any aluminum showing on the RT.
:congrats::clap:
Thank you for posting this! How much effort is involved in removing the Handle Bar?
This will be much easier for you if you have a service manual. Biggest step is removing the "Console Module" which also includes ignition switch removal. One step left out in procedure outlined in service manual is removal of "Front Compartment Latch Assembly". Failing to remove the latch assembly will prevent lifting of console module. If you run into trouble, PM me or PM Stripperking. Stripperking helped me a lot.
Good luck.
