Car tires on the spyder??
TIRE / SUSPENSION THOUGHTS
On the Michelins to get that kind of mileage they have to be very Hard, that's why they wear longer..........And doesn't the rear fender go up and down with the rear swing arm ?...that's what it's attached to , so how can the relationship between the rear tire and rear fender change ( space btwn the two ) ??????.......Mike.....:thumbup:
I may have mis-spoken. By rear fender, I meant the area under the saddle.
Just put car tires on the front, and i was wondering about the tire pressure. Dealer said i should run them at 17 psi just like the factory tires which is way below the recommend psi for this tire. any suggestions?
I would guess that a "car tire" should be able to handle running down as low as that...
which tires and what size are you running up front?
It's falken -I think the size is 185/60/14. The bike is at the shop so i can't verify or take a picture.
