cannister gone... raw gas instead
Sny
I had the purge valve disconnected and plugged for several months, ran great, but that short hose off the evan can bothered me so recently I decided to finish the job.
After removing the cannister and running the vent hose somewhere below the radiator, both our spyders leave a puddle of raw fuel on the ground whenever we stop after riding in hot weather.
Seems excessive. No wonder that cannister was so big, I bet we drop a tablespoon every time we stop.
Wondering if I should put a filter in the line or something to slow it down and give it a chance to run back into the tank. Or maybe route the hose as high as it can go for as long a length as I can find room for before going down and out.
Certainly runs better this way, but the gas smell is just as bad and now we leave raw fuel on the ground everywhere we stop... including the garage :yikes:
Any ideas?
Any ideas?
Are you over filing your tank??? The can should be collecting fuel vapors not raw fuel as it is connected to a vent line. I kind of find it odd that your getting that much fuel out of the hose. How do you fill up the bike, are you topping it off a lot at the pump??
You should not be getting raw fuel. Make sure the vent hose (at some point) is higher than the top of the fuel tank. Otherwise, you're getting raw fuel in the vent hose when it should only be handling vapors.
You may want to run the hose out the back of the bike following the red brake fluid hoses. Havent had any problems so far and its been about 2 years now.
