Can it be set back to default settings or once its done its done, unless they install it again?
I was so happy with my spyder before I had it done. I even thought about not doing it, but I thought better safe than sorry. Now I am SORRY!
The handling was great, it ran smooth at lower rpm, and pulled hard from 4K rpm up in any gear. Now it surges trying to hold a constant speed, check engine light comes on from time to time with "CHECK DPS" scrolling with no powersteering, high speed cornering the steering is too sensitive, and acceleration isn't what it was. Before if you were cruising in 5th gear at 65 or 70 and came up behind someone driving say 55. If you let off and coasted down to there speed until it was clear to pass, you could stay in 5th blip the throttle and be gone. Now you have to down shift because it won't pull hard unless you are above 5k rpm. It just seems more sluggish, maybe they did flatten out the curve to help gas mileage. I liked the performance, maybe the fuel update could have been optional. Also if I turn on the JB, even at half the numbers we were using, it pops and backfires on decel.:gaah:So it's pretty much useless for me now.
Ok. Sorry, rant over.
I just miss the good ol days
ray:
Thanks, Chris
Thanks, Chris
