Can someone with Stage1/Stage2 test eco mode for me ?
donhy
I just recently had ECU reflashed to Stage 1 and I've lost my ECO mode, the green light will turn on but there is no difference in power between the two modes and the upshift indicator is no longer there, can someone test this ?
Ill test it today for you but why would you want to even use Eco mode? It is a pretty useless mode even without the flash.
Why would you want ECO after getting a flash for more performance?
If I run into a situation where I want to make every drip count i want the option to be there. Steve told me he doesnt touch eco mode but it literally worked just before i took the ECU out. Similar situation to a supercharged jetski i had ,it was all supped-up and could burn a tank in an hour or if im in the middle of no where i turn eco mode on and sips fuel until i hit the next gas station.
Well I turned it on and had the same thing you had the performance is the same and no up shift indicators . If you are worried about economy, it does not use any more gas than before but that also has a lot to do with how you ride. On long stretches just take it easy.
With the flash, you can cruise at low RPM much easier because of the increased torque. I can putt along and feel plenty of power to maintain my speed more so than before. I do not feel the urge to downshift unless I get the need for speed.
Thank you for confirming.
