Can someone help me or direct me???
TracytATL
I need help removing my rear fender. I have searched for a step by step or tips and didnt see anything. Is there a link or thread about this I am missing. I removed the side panels to replace my battery and I want to get it all out of the way while she is taken apart.
http://www.spyderlovers.com/forums/showthread.php?40911-RS-GS-Spyder-Breakdown-Arntuf
If the above link doesn't work, do a search for arntufun, then click on his link in his signiture line. He's done an entire video series on breaking down an RS/GS :thumbup:
Sorry bout that, but you'll have to do the leg work on this one
But if you go toward the top right side of the screen, you'll see a rectangular white SEARCH box, that's your friend on here. I typed in 'rear fender removal' and got bunches and bunches of threads as displayed in the following link. I went thru a few to see if I could find step by step, but don't have enough time to go thru them all, but hopefully you'll be able to find it there. Good luck.
http://www.spyderlovers.com/forums/search.php?searchid=1228376
Assuming you have an RS, there are 4 bolts on top of the fender that hold it in place. Remove the tail light first, then the bolts.
The rear fender is 2 pieces. Under the plastic fender there is a steel fender. The 4 bolts hold both pieces. Be careful of the tail light wiring. It is sandwiched between the 2 pieces and can get pinched when you put it all back together. I know this first hand.
If you have an RT, I can't help you.
