Can someone explain the physics of how a tire balancer liquid works?
TOADS
I confess I am at a loss to to explain how a tire balancer/flat fix like RIDE-ON works. The flat fix part is a no brainer. However how it balances the tire is not so intuitive. From the available use descriptions it appears to spread as a thin layer on the inside of the tire and rotational inertia should spread it to a relatively uniform thickness, but how does it weight the area in need of balance weight? Or does it simply increase the total rotational inertia of the tire and reduce the the out of balance moment by increasing the total tire mass making the needed balance weight a smaller percentage and thus less noticeable.
Thanks, TOADS.
I confess I am at a loss to to explain how a tire balancer/flat fix like RIDE-ON works. The flat fix part is a no brainer. However how it balances the tire is not so intuitive. From the available use descriptions it appears to spread as a thin layer on the inside of the tire and rotational inertia should spread it to a relatively uniform thickness, but how does it weight the area in need of balance weight? Or does it simply increase the total rotational inertia of the tire and reduce the out of balance moment by increasing the total tire mass making the needed balance weight a smaller percentage and thus less noticeable.
Thanks, TOADS.
You don't need any help with this, you've got it sorted already! (y) If you want a label for it to impress the mob at the pub, you could always use 'Centrifugal Force', or better yet/more correctly, try 'Centripetal Force', but really, it's juuust a little bit from your Column A above, plus a little bit from your Column B... and Voilà, problem solvered! :p Nett result, tire spinning smooottthhly! ;)
I have a similarly hard time understanding the balancing beads, too. Even though everybody that has tried them has said they work, I just don't understand HOW.
For the time being, I will stick with the cancer-causing hunks of metal that still seem to work just fine.
I've seen a video of a water bottle with beads hooked to a drill, and it worked. Seems counter intuitive.
Seems like if I put balance beads in a slingshot it would never spin.
This guy put a GoPro inside his tire with balance beads, also tested balance on a machine. He couldn't explain how they work, but read the comments where some have tried to explain it.
