Is it possible with an F4 windshield attached?
Forget SlingMods video. That nose piece does not slip off when the bottom screw is taken out. There are side screws on my 2022 F3-S. If I could get the upper panels off, there should be access but I am stuck getting them off. Now the shop manual says to remove the top rails. That is what the F4 windshield is attached to. What a major hassle that could be just to avoid damage.
After the top rails are removed you are supposed to remove the gauge trim, the entire gauge, the gauge support and more. AHHHHHG! It would take devine intervention to change a headlight bulb at an auto parts if you need to on the road. Surely CanAm is not so ingrate.
From what I can see just getting that nose piece and upper panel off would give you headlight bulb access. If you look at the wiring and mounts I did to power the GPS and charge the phone, removing the windshield would be obscene confusion.
Got ideas?
Got ideas?
