Can Cruise Control for 2022 models be added as an accessory for earlier models?
kml354
I hope that the cruise control that can be ordered on the 22 year model can be added as an accessory to the other years.
If it can be done someone here will figure out how to do it. In case you're not already aware the CC on the Spyders is all software. On an F3 someone figured out to modify the right side switch module to activate it since it was already in the s/w. If it can be added to an earlier Ryker most likely the ECM, and who knows what else, would have to have a major s/w update since I understand Ryker has not had CC in the past. Don't plan on BRP making a retrofit available.
