Can Am starts and runs, but no dash, horn, turn signals ... HELP!
laser1972
Just went and visited my friend on my Can Am, recently I had all the replays changed out (it had no power, no anything so took it to service dept)
Now, after i left his house, i thought the same thing, turned the key, no dash, but headlights, breke light all were on..
I took a chance and hit the starter button and it started right up, he followed me home to make sure, but ran fine..
Any idea why I am getting no display on cluster and no horn, turn signals, etc..
Maybe another relay again?..
Thanks for any help or guidance
Hi 72, Can am doesn't make relays, they buy them from the CHEAPEST supplier, so you may have gotten a bad one. Try switching a few around and see if the lights come on. Of course check the fuses.
It REALLY helps if the forum knew the year and model of your:spyder2:
Good luck---- help is coming.
Lew L
sorry 2009 SM5 model.. i will switch the 3 smaller relays around, I dont have a spare for the main one, I might just pick up the relays tomorrow and stick them em..
I hope that is it, maybe i should buy a spare set.. This is the 2nd time this summer, glad I wasnt stranded like last time (and with the wife on the back)
Last time, it didnt even start, I am glad I still was able to drive it home
UPDATE, i switched around the 3 black relays on the right side, and it worked... I will be picking up 3 new ones for spares anyway
I did notice 1 had a different model number than the other two.. Does that matter?.. i know, probably dumb question
I am assuming the one is the main relay 2, and the other two are fan and headlight
Hey Laser, has your 2009 GS/RS(?) Spyder been running OK since your last thread about it dying?? :dontknow:
https://www.spyderlovers.com/forums...der-but-died-this-morning-any-ideas-THANK-YOU
Knowing all that went on from that older thread might make it a little easier to help now, especially if you've already put in a new battery AND the problem has persisted so much/long that you've recently had it in to the Service bods to get it checked & resolved..... or at least 'played with', if not actually resolved! :rolleyes: It does sound as tho you've now got a good (new?) charged battery that doesn't break down under load (altho even new batteries can fail & cause all sorts of problems, just not usually like the issue you're telling us about now! :p ) The 'starting & running OK' bit, albeit with no other electricals at all, does sorta make it a bit odd & waay less likely to be the battery &/or terminal conections?!? But have you (or the techs) actually checked the battery connections & all the wiring loom earths; as well as the battery's resting voltage, voltage under load, and its charging voltage?? :dontknow:
Still, I reckon you'n Lew could well be onto something with the relays idea - just about everything you've mentioned as 'not working' this time around is run off one or more relays &/or fuses, while the engine & charging system is pretty much run off a different circuit/relays/fuses etc; so it could well be that you've got at least one dud relay in amongst the rest; or maybe it's the 'load shedding' relay itself, which isolates all the extraneous electrical loads from the important running electrical load?? :dontknow: Relays can easily be either not seated properly; incorrect for that particular spot; or just plain dead, even if it is a brand new relay..... Then again, BRP has (allegedly ;) ) a bit of a questionable track record in letting their suppliers cut corners on quality control in order to allow BRP a better profit margin when they on-sell the tire... err, sorry - that should be parts to you :rolleyes: so it could well be something like that.... :banghead:
Anyhow, the relays & fuses are probably a good place to start, but I wouldn't necessarily rely on your dealer/techs being all that good (or cheap) at tracking down a problem like this - so how handy are you with a multi-meter?? Good Luck anyway! :thumbup:
Your welcome--------------
