Can Am backrest on 2014-RT Touring -- Can it be adjusted for driver comfort?
UNCLEDAVE
Is it possible to adjust or reposition the factory backrest on the 2014 RT Limited? i.e. Tilt it back a bit so driver doesn't have to maintain a rigid straight-up position?
I put a half inch spacer on the back end of the seat between the seat and the bracket and that helped somewhat. feel free to call me and i can explain 501 580-5595
Cruzr Joe
Couple of questions....
Cruzr Joe
Cruzr Joe, I didn't want to bother you yesterday evening with below. Exactly where did you install the spacer?
Under the seat?
or
Did you remove the zippered backrest cover & make changes in that area?
Thanks a bunch!
Under the seat?
or
Thanks a bunch!
i put the spacers between the bracket under the seat and the bottom of the seat which made the bracket tilt backwards a little bit.
Cruzr Joe
Crafty idea!
Cruzr Joe
After carefully examining the underside of my seat assembly early this morning, I thought that might have been your solution/fix. So, the end result is that the (underside) supporting plate is angled which in turn skews the backrest toward the rear.
I will try that & thanks again for the great idea. There appears to be enough clearance under the seat assembly to accommodate the spacers!
Un. Dave
Un. Dave
good luck
cruzr joe
