Calling all 2014-2015 RT owners with "Belt Vibration"
SpyderCruiser
Hello all,
With close to 2,000 miles on my Spyder, I'm trying to find the source of the vibration at 75 MPH. I had a vibration at lower speeds, tightening the drive belt seems to have cured that. I performed an experiment today on the highway - I was certain the vibration was caused by the belt (from what I have read on this forum). However, when it started I wondered why the engine seemed to labor or hesitate at the same time.
So at 75 mph where the vibration is worse, I down shifted to 5th gear, lo and behold, the vibration was gone. I adjusted my speed above and below 75mph, no vibration. I could not cause it to occur in 5th gear. As soon as I shifted into 6th the vibration started up again. At 75 mph in 5th the motor is turning at 4,500 rpm, and I certainly do not want to drive at that speed at that rpm. It kind of defeats the purpose of having a 6th gear!
I would like for other Spyder owners to "experiment" and see if this causes your vibrations to go away too?!
And a question for the experts. Why does it occur? I am no expert, but I do not feel it is a harmonic issue, as when it occurs the engine seems to have a "flat spot" and hesitates. Almost like at that particular rpm and engine loading, the fuel mapping or timing is not quite right...
This would not be unknown on Rotax engines. We own a Sea-Doo jet ski with the 4-tec 1,500 cc 3 cylinder 4 stroke motor. At 4,500 there is a hesitation that's so abrupt that the rpm gauge fluctuates if you keep it there. Many 4-tec owners experienced the issue and the dealers all said to just keep the engine out of that rpm range. There was never a fix from BRP to address it. Ok, that works for a jet ski, cos there's no speed limits on the water. But certainly is not going to work for the Spyder. Most of the highways we drive on, the traffic runs at around 75 mph. I do not have the option in traffic to set my own speed just cos because my Rotax motor vibrates.
I can just see the look on the Police officer's face if I tell him that I am speeding so my motor won't vibrate! :roflblack:
I hope all you other 1330 owners can perform this "test" to find out if mine is an isolated issue, or if other Spyders are exhibiting it as well. This thread is not to "flame" BRP, we love our Spyder, and just want to get to bottom of the issue.
Take Care,
Louie and Meg
It has been described as a "Harmonic Vibration". Perhaps by dropping a gear, you're just moving the frequencies around enough that it stops the vibration? :dontknow:
:shocked: I Haven't noticed it on my 2015 RT. I've had her up to 100 and haven't noticed vibration at any speed :dontknow:
Pam
You are one exceptional ryder.
I'm willing to try your experiment though. For me, the "vibes" set in at 4k rpm in 6th. I haven't noticed any unwillingness for the motor to power right on past that, though.
I notice a vibration on my 2015 rtl at 78 mph have not been over that because I don't want to ruin something or my self. Trust me I am not one to be easy on the throttle. Did not now if it was wheel balance or some other prob.
Same issues with belt / Vibs
nojoke
Hello all,
With close to 2,000 miles on my Spyder, trying to find the source of vibration at 75 MPH. Had vibration at lower speeds, tightening the drive belt seems to have cured that. I performed an experiment today on the highway. I was certain the vibration was caused by the belt (what I have read on this forum). However when it started I wondered why the engine seemed to labor or hesitate at the same time.
So at 75 mph where the vibration is worse, I down shifted to 5th gear, low and behold the vibration was gone. Adjusted my speed above and below 75mph, no vibration. Could not cause it to occur in 5th gear. As soon as you shift into 6th the vibration starts again. At 75 mph in 5th the motor is turning 4,500 rpm and certainly do not want to drive at that speed at that rpm. Kind of defeats the purpose of having a 6th gear!
I would like for other Spyder owners to "experiment" and see if this causes your vibration to go away.
And a question for the experts. Why does it occur? I am no expert but do not feel it is a harmonic issue as when it occurs the engine seems to have a "flat spot" and hesitates. Almost like at that particular rpm and engine loading, fuel mapping or timing is not quite right.
This would not be unknown on Rotax engines. We own a Sea-doo jet ski with the 4-tec 1,500 cc 3 cylinder 4 stroke motor. At 4,500 there is a hesitation so abrupt that the rpm gauge fluctuates if you keep it there. Many 4-tec owners experienced the issue and the dealers all said to just keep the engine out of that rpm range. There was never a fix from BRP to address it. Ok that works for a jet ski, no speed limits on the water. But certainly is not going to work for the Spyder. Most of the highways we drive on the traffic runs around 75 mph. Do not have the option in traffic to set my own speed because my Rotax motor vibrates.
I can see the look on the Police officers face when I tell him I am speeding so my motor won't vibrate!:roflblack:
Hope all you other 1330 owners can perform this "test" to find out if mine is an isolated issue or if other Spyders are exhibiting it as well. This post is not to "flame" BRP, we love the Spyder and just want to get to bottom of the issue.
Take Care,
Louie and Meg
I've had the same issues with the vibration between the 71-78/80 mph range. Did the drop down to 5th gear changes vibration range, less vibs. Shop said 1st time might be tires, Shop said 2nd time belt vibs.
[]:shocked: I Haven't noticed it on my 2015 RT. I've had her up to 100 and haven't noticed vibration at any speed :dontknow:
I'm willing to try your experiment though. For me the "vibes" set up at 4k rpm in 6th.
Haven't noticed any unwillingness for the motor to power right on past that though.
Not so much an exceptional rider, as an experienced rider on an exceptional machine :ohyea:
I don't cruise at 100, I normally cruise at 80 (Speed limit here is 75). But when I need to, I know I can kick the RPMs up and easily get up to 100. Again, I have not experienced any vibration. Maybe I'm lucky :dontknow:
Pam
We've felt a little if it two up at about 70 mph. Will first attempt belt dressing to see if that corrects or reduces the issue.
BELT VIBRATION
14's and 15's are not the only ones to vibrate, my 13RT-S vibrates between 70 and 80 once you get above or below It's OK..
It's normal..
Stay in 6th gear and go above or below the "problem area".
I pretty much ignore it now.
Riding down the interstate yesterday, and rolling along at 80 mph 2 up 2015 rtl and when I came to a little incline or hill to go over I started to get the vibration. It never stopped when I got to the top either, Unless I just bumped the RPM's and then it would go away. I am a firm believer it is the belt. I am going to have my wife try and hold a camera down there to see if I can see if the belt has a shaking or a vibration to it. because it does it on every hill. Wife kind of liked it though she said it was like a foot massage. Well that is not needed on a spyder.
Belt vibration is common
There seems to be little or nothing that can be done to cure it. BRP definitely knows about it but will not address it. Adjustments, belt tensioners are about the only alternatives available to diminish the problem; but it seems it will never go away. RPM's, road conditions, bike loading are just a few of the many influences that can cause belt vibrations over and above belt adjustment. I've had my belt adjusted numerous times to try and eliminate the vibration but to no avail. I have about 12k miles now on my 14 RTS SE6 and the belt tension is approx. 230/260 on the cricket II gage, with the tire resting on the ground. This is a very lose adjustment according to spec's, however, for the way I ride it seems to provide me with a the appropriate sweet spots in most conditions. I've read about this problem and screwed around with adjustments until I'm blue in the face, but nothing will take totally away. There are posters here that do not experience belt vibrations and there are some, who like me, can not cure it, but just live with it. I do have one caution for you, DO NOT OVER TIGHTEN your belt in an attempt to eliminate the vibration. That could end up being very costly. :lecturef_smilie:
Thanks for all your input so far.
I have noticed the vibration increases when going up a hill as well. I am basing my opinion that it is not the belt, because a tensioner did not cure the issue.
Going to tweak the tension, but check the rear wheel balance when replacing the tire
With 10,000 miles on the OEM Kenda the 15 RTS is ready for a new shoe, and have a Kumho waiting in the wings. Have noticed the 68-70 mph vibration as others have noted usually when loading the belt on an upgrade. I am hesitant to up the tension but willing to tweak it up or down.
First goal is to find a shop with a balance machine that can handle the groove on the wheel rim and get a true spin balance. I have used the Harbor freight static balance stand and Ride-On on one of the 3 rear tires replaced on the 11 RT, but maybe the Firestone shop can help as others have mentioned.
If not--- anyone know where I can get some more stick on weights? I usually recycle the old ones, but notice the rear rim on the 2015 doesn't have any. Could it be that the balance was perfect from the factory? HMMM......
I have been invited to a trip here that is 4 days long to Puerto Vallarta. But today when I was going to Costco about 71 miles per hour this vibration started and scared me. I have gotten it up to 76 and that seemed a tad better, but it is sorta scary to me for some reason. The vibration makes me pay attention and so I slow down a tad. I cannot imagine anyone going 100 on the Spyder! yikes, at least not me, not yet. But this has me a bit worried and I am hemming and hawing about this trip, do I go or not. It is going to be hard and exciting too. My Can-am agency is about 2 1/2 hours away on a very tough road, maybe to tough for me yet to use yet, no one wants me to take it over there, the road is curvy, cliffs to an end-less bottomless pits.....so it is something I am debating alot in my brain. I bought my bike used, and have never been to a Can-am dealer. This agency wants me to go a day ahead of the trip to check out my bike. I would leave from there with them, about 20 Spyders....and the roads from then on are much easier...whew....
A side note: I was shocked today going to the Costco on my Spyder! I saw another one! Whoo hoo, he waved at me, I waved at him and I turned around pretty fast and tried to catch him, silly me, that wasn't going to happen of course. He was going pretty strong....but there is another one in my realm in the world! HA! I hope to see him again sometime and catch up with him!
If I were placing a bet, I would put my money on out of balance tires. Have you thought about dynamic balancing? Much better than those stupid weights.
Pam
I wouldn't worry about the trip, the vibration is normal around 70MPH, go slower or a little faster and it will probably stop. As for the dealer visit, you probably will learn something. If they don't havr a good rep, then maybe find another dealership, even if it isn't a CanAm dealer he can do some stuff.
