Buzzing sound on left side
Geep
Intermittent buzzing coming from beneath plastic under left hand side below wind deflector....what’s in there? No codes up 2015 RT SE 6
So the sound appears after moving the handle bars left or right when riding two up...no codes up...is there a power steering pump?
These Spyders DO have 'electric power steering', but there's no power steering pump as such! How loud is this buzzing sound?? :dontknow:
Are you sure your noise isn't the compressor for the ride-height airbag? :dontknow: The 'source location' of noises like this can be quite deceptive when you're sitting on your Spyder with the engine running, and that's especially so if you've got a helmet on!! :rolleyes:
The compressor is under the pillion seat, and it only operates with the engine running & someone on the rider &/or pillion seat; but it can operate at the slightest change in position or movement from a rider/pillion, or if the ride height varies due to something like turning the handle bars.... And, the air bag ride height system, the ACS, is also juuust a little problematic & prone to leaks & failures that may result in sporadic &/or random compressor operation. I've had more than just a few owners swear to me that they have a noise coming from 'below the dash' when it's actually (& definitely!) turned out to be the compressor doing its thing for whatever reason, and that's definitely a fair bit further back than 'below the dash'!?! Worth checking?! :thumbup:
