Bulb replacement
Cindi
As you sit on the RT, I have a right hand headlight out, and a left side fog light out. Can someone walk me through replacing the bulbs?
Are the bulbs standard replacement bulbs I can acquire at my local auto parts store?
Searach??
Hello Cindy,
If you search there are a few threads/ videos on changing out the headlights/ fogs. The headlights and the rt. fogs aren't too bad. THe left side fog is harder and frustrating at times but I did change them all to LEDs ( HIGHLY RECOMENDED ).
You can get replacement bulbs at auto parts stores.
Lew L
You have not stated which year model your RT is
Ref the Fog lights
All the videos I could find were for pre 2014 RT’s they are easier to get access than the later RT’s esp on the LHS as the air intake gets in the way
I found the easier way was by removing the Front funk
Videos for headlight bulb replace is the same for all model years of the RT
see this thread
http://www.spyderlovers.com/forums/showthread.php?107418-Fog-Light-Bulb-2014-RTS
Hope this helps
