BRPConnect glitch fixed
Flamewinger
I have had some problems with starting the app on the dash. I see the phone go dark but the dash tells me to connect the phone. Thing is it is connected so why the problem? I checked the USB connection as well as the lightning phone connection as lint can get into the tiny hole where you plug the cable into. Nothing worked until I shut the phone off for a few minutes. Then, when I turned it back on and plugged it in the apps showed up in the dash. Not sure if its a memory thing or what but the iPhone 10Xs Max should not have storage problems. Weird.
Basically shutting you phone down once in a while refreshes it and helps it to work better.
My Samsung is the same way with the restarts, although my machine is a '17 RT and doesn't have BRP connect. Every morning at 3am it's been told to reboot itself and voila, everything is now right in the world.
