SpydherLuv
The BRP connector is a 9-pin connector (it uses 6/7 pins). There is no commercial adapter available. To connect to a 5-pin trailer you can either make an adapter, or change the trailer connector to a matching unit. The Deutsch connector parts are available online, but the best way is to purchase the BRP 2010 Trailer Tongue Harness P/N 710002029. Do not use the 2011/2012 Pole Harness, it is made for a 4-wire trailer. Once you get the harness, you can either fabricate an adapter using an additional 5-pin trailer socket, or you can wire the new harness directly to your trailer. The wire identities are labeled on the harness. There will be an extra brake light wire, just choose one or the other and tape off the unused one. Be sure and leave enough length to reach the Spyder connector. It is farther from the hitch than normal.
Perfect. Thanks for saving me time trying to find an adaptor. I'll call my dealer tomorrow and order the tongue harness.
-Anita
