h0gr1der
I tried something with my dealer.
My 2018 RTL is experiencing the dreaded parking brake not releasing issue. Once it sits awhile it clears up, leaving only the code behind. So in anticipation I called my dealer parts department and asked them if they have in stock a #278003071 control gear motor (commonly called the parking brake motor) and a #710006574 Left Housing Switch, Automatic. They did have the motor, but were back-ordered until June 3rd on the switch housing. I need to schedule a warranty fix, and strongly suspect the motor, because each time the bike recognized the brake had been released as it didn't beep when I tried (unsuccessfully) to drive off.
So, as a small litmus test, if the dealer isn't stocking, or have on backorder the very parts that are failing the most, you have to wonder if they're really doing as good as they can to serve the customer. If they don't carry the common wear items, like brake pads, belts, etc., I'd consider a change of venue. Just my $0.02
