BRP Stitched Seat Cover
Rando
I purchased an RS seat awhile ago that came with the BRP Stitched Seat Cover alreadly installed. I am trying to remove the cover. Since I didn't install it, I am at a loss as to how to remove it.
Can anyone help me out? It appears it was installed with one way plugs that probably will not be reusable if I pull them out.
Thanks!
I have done the installation of on my spyder & actually upgraded to the comfort seat after the fact. So anyways it helps a lot if you totally remove the seat frm the bike. Or at least disconnect the seat shock and rear tail piece or sportrack. With those removed you should be able to fold the seat backwards to have access to the pins. You should be able to replace the pushpins at harddware store. For really cheap in not reuse able
