Great!
I am not a Lamonster but I play one on TV...
:clap::roflblack::clap:
Funniest thing I have ever read on this forum . . . . .
From all the other threads on the update, my take is that there are a variety of factors, conditions and combinations that trigger "problems". If you can control one of the factors, you may lessen or possibly eliminate the "problems" until another Perfect Storm occurs - if it ever does.
My stock 2008 SE5 Spyder has been great since the update. Different, but great and nicely improved. The day before yesterday, I left the Spyder in the driveway before I was going to run some short errands. High 90's air temp, 6% humidity, full gas tank, and in the Sun. When I started the Spyder, the dash showed Zero Engine Bars and a Temp of 125F. The Spyder did not run as badly as some have described, but certainly not as well as it had been. Hesitations on starting to move in 1st, but 7mph in 1st at idle, and it just didn't seem as "smooth" - no backfires or anything like that. About 5 miles of errands, no speed over 35, the Engine Bars got to 3 and the Temp down to 113F. It was running a little better, but not normal.
I do this type of ride at least 5 times a week. Never felt like this before. Has not done it since. Since that one ride, it has been running great.
Maybe the 125F Temp gave it a data point that computed out some bad values for the different systems and things got a little rough. Maybe it was something else.
There seems to be a lot of variability in how and when the Spyder manifests some of these running issues. There does not seem to be one thing to be done that will fix everyones problems. I think someone posted in another thread ( Scotty, maybe ), that the update moved the Spyder systems closer to some operational and setting limits. That could expose some equipment flaws that were not noticeable before. And it could be more sensitive to some outside factors, like heat or Ethanol content of gas, and so on.
One theme that is common though, is that for many, the Spyder seems to "adjust" or "learn" its way out of the problems. Or maybe the Perfect Storm conditions are just not there.
One final point, I really dislike the statement; "its just something you will have to learn to live with." Especially without looking at the specific case and being able to compare it to a measurable baseline. How do they know that you are not experiencing unusual and dangerous surging? That is sloppy, irresponsible, uncaring and totally unprofessional. I realize that it was 'hearsay', but it did sound like the dealer accurately captured it. When ever you hear that statement, you know you are not getting Support, Service, Aid or Assistance - you are getting the "Brush Off".
Tom
