BRP Power Outlet Question
F650624
I have no electrical power at either the front or rear accessory circuits on my 2015 F3S with key on or off. Test is with a working multimeter. The accessory circuit fuse test ok and has been replaced. The unit is "new" with only 672 miles and just started riding.
Try it with the engine running. The accessory circuits are powered by the Load Shed Relay and only work if the engine is above 800-900 RPM.
They are only 'live' with the engine running. Have you checked them then?
The only accessory circuit live with just the key turned on is the one for the GPS that is buried down the right side of the bike. Do a search as there are threads showing it's position.
