BRP Connect question
I have a 2019 spyder rt limited. Is it possible to use the maps and listen to xm radio streaming to the bike speakers at the same time?
Salesman had told me he did not think it would do that.
I have a 2019 spyder rt limited. Is it possible to use the maps and listen to xm radio streaming to the bike speakers at the same time while viewing the map using brp connect
I have a 2019 f3 ltd and have not been able to do it. i have used apple music to stream its channels but mostly use play lists . thinking of adding a xm receiver to the aux jack.
Yes In a way. You have to start the XM music before connection to the bike. Start the music, Start the bike and wait for the BT connection then plug the cable in. Go to the music app in the dash and hit play.
I play the radio in the iTunes app and start it first before connecting to the bike.
There is also the problem of the music only working with the BT, so not sure if it will play in the speakers.
