Brown dust on rear tire
Tatonka
2013 rt-s sm5.... first thought brake dust but it's on the drive belt side of the tire....brake side...nothing.....ideas?
Interesting....🤔
Brown dust.... not a clue unless it is more to the red side of brown which could be from the engine pulley area transferred by the belt. I get a lot of black but never brown unless I have been on some dusty roads....:dontknow:
Yeah, drive pulley failing is what came to my mind. Although, it seems to be more common on newer models.
I saw similar. I think the pulley bolt is $12 or so; pulley is decent price at cheapcycleparts.com. Mine (bolt) came with the yellow locktite already on it. I added blue. Some threads were getting wonky, and the bolt came out with little effort. Probably a good idea to replace regardless. Was a BRP tech bulletin on this to torque the bolt higher. I forget the final number, but my manual said 89ft/lbs. There are several good threads here on that bolt and pulley!
EDIT: On a 2008GS - so it happens to all bikes! A friends 2008GS sheared the bolt off, and the pulley took off in a field, lost forever! Also checking torque on my 2013 STL it wasn't right, replaced bolt even though it looked OK. For $12, not taking chances.
The video was informative....if I start hearing a sound I'll know what it is. The color could be rust... hopefully that could be from the bike setting for so long before I bought it ....
It might be worth having it checked out; peace of mind.
