Kansas Spyder
Well, it started off as a good morning. Temp around 28 to be followed by sun and warming up to 40. Got all dressed up with my heated gear, hopped aboard the ol"Spydee, and stuck the key in the ignition. First thought was that didn't feel right. I took the key out thinking maybe water caused ice to form inside. I stuck it back in to see if I could dislodge the sticking pins in the lock. It must have worked as the key went in, so I turned the key to the start position only to find out the key had snapped. So now I have part of the key in the lock and the rest with me. Has anyone had this happen to them and if so what was the solution? I figure the answer is to bring it to the dealer and suck up the cost of new keys and the ignition switch. I'm sure a broken key is considered abuse so I'm prepping for the worst. I didn't use force turning the key since it wouldn't even go fully in the lock at first.
Or, should I just leave the broken part in the ignition (you can't see it) and use the top section of the key to turn the ignition switch to ride?
Think I'm going to get an IPS while at Spyderfest and leave the key in to avoid this again.
