have a 2008 spyder gs , had the brake failure light come on , has not gone into limp mode , checked brake fluid , of the 2 m/cyds under the seat the rear most one has fluid up to the cap and would be overflowing if not for the cap , no fluid had been added , the other m/cyd is at its normal level , the brake pedal now has a lot movement/play where before it was normal , as said has not gone into limp mode and the brakes are working , its the brake failure light thats come on ..not the abs light .. was told by a mechanic mate who doesnt know spyders can be a common prob in cars with a tandam m/cyd set up also possible abs prob due to a stuffed by pass valve... any help would be great as no canam/spyder work shops near by
