Brake Pedal Lowering
sabunim5
I would like to lower the position of the brake pedal. Has anyone out there done this yet? If so, a post in the How To section would be greatly appreciated. Started to read the adjustment section in the Shop Manual but it put me to sleep. Thanks in advance to any kind soul who has done this and posts it. :bigthumbsup:
sabunim5 :spyder:
I dont have mine yet, but from the parts schematic, It looks like you would need to shorten the actuating rod by screwing the yoke farther onto the rod. Dont forget to adjust the brake switch too if it messes with that!
convert
yeah Both of the switches.. There is a switch that triggers the brake lights and then the imfamous second switch below it that will trigger the Brake failure error code on the console.. Careful or you will suffer as I do.
