Brake oil tank
xpbqn
Does anyone has loose caps on the brake fluid tank? Mine is loose and I do see some comes out from time to time.
Brake Fluid
It always helps when you tell us what kind of Spyder you have, what year it is, etc.
:thumbup:
Cruzr Joe
What bolts?
Bolt holes may not be tapped all the way, someone put the wrong length bolt on that unit, something in the bolt hole, bolt not threaded all the way.
Very strange situation there. Let us know what the fix is.
:hun: What bolts Ron?
reservoir caps
mine have been leaking for a while. i just ordered new ones from our local dealer. 21.95 plus shipping.
Sounds like the mounting screws may be too long. Maybe the o-ring is the wrong thickness. Cap should set on the reseviour with a gap then compress. :thumbup:
My surprise
My bad, brain malfunction. Thanks for catching that. Can I get a Mulligan on that one? :opps:
Sure you can. Your answer just caught me by surprise. Generally you offer sound advise and thoughtful opinions and I wondered where that answer came from.
Well, the dealer said that was just overfilled.
But, to me, how the hell the dealer overfilled it? Careless...
My 2012 RS-S came to me with the low beams set for coon hunting. When I would drive at night people thought I had my high beams on. You think they would check these things eh? No big deal though, easy adjustment and allows me to get a little closer to my spyder.
If I were you, I would adjust it a little lower depending on how heavy you are. 'Cause your weight + setting low beams a little high will shoot the light up sky and will hurt oncoming vehicles.
Oh, yeah, they'll check those things for you.
Just my 2 cents.
