Zenagirl
GOS member (Girls On Spyders)
Another problem that has been discovered with the STs is that some brake lights are staying and draining the battery. I had to have my Spyder jumped started at work one day when I forgot to tap my brake to make sure the light turned off. Most times I have to keep tapping the brake for quite a while in order to get the light to turn off. I visited a different dealership yesterday and talked with them about this problem as I had forgotten to mention this when I had my first service done at my usual dealership. They told me they've seen this problem twice, and that this is a little known problem with the STs. Something is a little too long, preventing the pedal from returning to the correct position and the light stays on. Says it is a quick fix, and they just need to "shave" it down a little. They couldn't fit me in yesterday, but will be getting it taken care of later this week. Said this would be covered under warranty. So, make sure your brake lights are off when you walk away from your ST.
