Brake fluid leak
7 Decades
Today was raining started to do some maintenance and saw a wet area on the frame in front of the rear shock. I removed the tupper ware and the upper frame in front of the reservoir had a area that the paint had started to blister. I could not find a leak . Two weeks ago i had it to the dealer to bleed and install new fluid. Because i had to pump the pedal. I know that is not right with abs brakes. Any help would be appreciated. Thank you.:yikes::yikes::yikes:
Check to see that the caps have the vent facing rearward (12:00 o'clock, if you can), regarding the leak.
As you surmised...brake fluid leak. The dealer could have merely spilled, or could have damaged something. I'd say it is up to him to make it right, and I'd take it back and complain.
As you already experienced that brake fluid does a number on paint I would have it back to the dealer and have him make it right .
