Brake Fluid Capacity
Purple Guy
Changing brake fluid on a 2015 RT-Ltd
Getting some conflicting info on how much fluid the RT holds.
2 different pages from my service manual, 1 says 1.75L - 1.85QT the other says 530ml - 17.9oz
Anyone know which is correct?
can't help....
cause I don't know the amount and have always filled to the full level or leaving enough space for the cap, If I fall short the nanny tells me right away...:joke:
Brake fluid
I think they both are. One is the capacity and the other is the amount of fluid required to fully purge and bleed the system. You will lose some new clean fluid in the process so they show the greater amount to do it. That's different from its technical capacity.
