Brake Flasher Module - any Plug-n-Play Suppliers?
I have a GearBrake flasher module for my brake light. A friend likes it and wanted to know where he could get one, but after checking, I see they are no longer in business. The reason I chose this one over ones like WigWag, was there was no splicing or cutting of wires, it was a plug-n-play set up.
There are quite a few of these companies that are no longer in business I see, so is there another company out there that has plug-n-play setup, and if so what is their name.
I love mine on our RT for the past couple of years......But will find out Saturday if it will still work with the freedom trailer I just bought.
$5 if you can solder.
I have a $5 flasher module from SuperbrightLEDs.com on my poor, old, slow V-Max. Has worked for 5 years without a hitch on the auxiliary LED brake light. I'm considering wiring one up for the Spyder. NOT PLUG and PLAY though. Soldering skills a plus.
Lew L
I have the GearBrake on my Versys 1000. It’s more than a flashing brake light. As soon as you close the throttle, your brake lights will flash, just from the engine braking, therefore, warning those behind you just a little sooner that you’re slowing down. So, a brake flasher & a deceleration warning.
Does the trickLED module flash the tour pack brake light as well as the 2 lower lights when on the Spyder and just the 2 lower ones when the tour pack is removed?
