Brake Flasher for 2020+ ?
I have 2 sets on my 2017. You can use them on the 2020 also just different kit. I really like the spyder pops ( turn, brake, flash) LED strips and I also have the dual strobe on the side of the plate from tricled. Everyone says they see when I hit the brakes. I like them both and together they really get your attention up high and down low.
https://www.signaldynamics.com/01004 This one is not plug and play, requires you to break the brake light wire from your brake switch. I have used this on all of my bikes, works well. Keeps repeating the sequence that you have selected for the entire time you have your brakes applied, no need to manually cycle at stoplights.
Al in Kazoo
Al in Kazoo
So what wire do you connect this to? Where is it located? I have a 2020 F3S...
I have the SMART BRAKE MODULE from st2-systems.com
When you back off the throttle it senses the bike slowing and flashes the brake light. Real handy when slowing down to let traffic behind you know that you are slowing, even though you haven't touched the brake pedal yet. It's about a 15-minute install. It went under the passenger seat on my ride.
