brake failure
Mine came on the other day and they had to add just a little DOT 4. They told me it had to run between the min and max or the error would go off. So with that being said I would think you could over fill it. The dealer then had to clear the code 1/2 hour labor.
Don't claim to know it all but that is what my local dealer told me
Hope that helps
Jim
If you overfill it; you'll end up with brake fluid running down over the rear framework... :shocked:
...taking the paint off in the process! :yikes:
Use an eyedropper to add it. This way, you can always suck a little bit back out... :thumbup:
