Brake Failure code
With the bike running and the fault error visible on the display, push & hold in the Mode button, the Set button and the turn signal cancel button (this is the center of the turn signal switch) all at the same time.
It should give the error code on the display.
99.9 % of brake failure code messages can be fixed by adding a tablespoon or so of the correct Brake fluid ...... many, many, many folks here have found this to work ...... good luck ..... Mike :thumbup: .........PS, if you don't already know Brake fluid is almost as corrosive as ACID .... cover the area around the reservoir's when you add fluid and wipe anything that brake fluid gets on ......M
