Bouncing Fuel needle on 2011 Spyder RT
.....I recall that you had some other electrical issue with a brake code. What's up with that, although I"m not making any connection between the two as of yet.
Update on P0504 code. Spyder has been at the dealer since Sept 12. Service Manager called and said "you as re not riding enough, the pistons on the brake calipers are not retracting fully after brake pedal release. Serviced the calipers, pistons and flushed brake fluid. Problem solved.
Just out of curiousity (and I'm guessing the answer is "yes"), does this work for all pre-'18 F3s (with the full gauge package).
Sorry, don't know about the F3s, but I can verify that it works on a '17 RT-S.
Tried suggestions, I can ride about 10 miles when it goes into limp home mode and flashes spyder light. Check engine light stays on. Next trip is on a trailer to the dealer.
Uhhh, this thread has been about a gas gauge issue, not about error codes or brakes.
Maybe you responded in the wrong thread?
But why do you say that Steve?!? :dontknow: It's all there, clear as mud!! :rolleyes:
I disconnected both gauges. Both are displayed digitally. However, the temp gauge shows bars. The fuel gauge is not working and the "fuel pump" light is displayed. Any suggestions?
It has 11miles since I filled up.
The needle would bounce slightly when I filled up. Then it would bounce more as the miles increased.
The "gas pump" light is intermittent.
As for the brake code, see the quote (that now displays properly ;) ) in lt538's post #21 re the brake code... :ohyea:
You're just not keeping up Steve!! :lecturef_smilie: :roflblack:
Sorry :opps: but I hadta.... :shemademe_smilie: :dg2:
:thumbup:
