IWN2RYD
Born on date for your RT or RS is???
Want to learn when our bike was built by BRP?
Well your friends @ SpyderLover is here to help....
From -Scotty... For the RT the month and year of manufacture should be shown on the VIN # sticker on the swingarm.
From docriverside... For the RT If you look through the vent just below the left mirror there is a sticker that has the model #, date and time. Use a flashlight it is near the top and forward on the frame. I found it when installing the GPS system. My first thought was this must be when they put it together.
From dlycan2... On the RS this information is located on a sticker at the front of the machine and is visible when you remove the frunk. This must be the equivalent of a "build sheet" on a car.
For example the date on my swingarm is 11/2008 and on the sticker up front 141108 1406 or Nov. 14, 2008 at 2:06 pm. It also identifies my Spyder as a Red RS 5spd. I have an '09 SM5.
It was kinda fun looking for this info!
hyea:
From IWN2RYD ... On the RS Instead of having to remove the Frunk... I found a duplicate sticker behind the Speedometer cluster. You only need a small Allen wrench, two hands and remove the Cluster to expose the sticker that is stuck to the main plastic framing on the bike (Not on the cluster)... In other-words... The cluster is in one hand.. and you look in the hole left behind from the removal of the cluster to see this sticker. BTW.. It was clear that this area gets wet because the sticker did show signs of being wet (I drive in the rain) so even if we wash the bike there is a good chance this sticker will not be readable for all...:dontknow:
pps:
So that makes 2010 RT-S SE5... BRP Born On Date of 8:50:49 on 01-20-2010
hyea
urchased 4-21-2010 ... Assembled 4-26 & 27, took delivery 4-28-2010 @ 5:33 pm in Enumclaw, WA. :spyder2::2thumbs::doorag::bowdown:
That means my wife and I had a middle of the week Orbital Blue RT-S!! :roflblack::roflblack::shemademe_smilie:
