Body Panel Part Two!
Tomline
Are the rubber grommets specific to where they are located? Specifically asking about the three that hold the LH Left Side Lateral Panel? Thanks! In checking mine they seem to have had some type of lubricant placed or sprayed on them. They to be deteriorating! Thanks
I did two things with mine. First I put a black zip tie through each one to hold it in place because I kept loosing them. I also put a dab of grease in each so the pin would slip in and not push the grommet through.
Solutions...
:agree: others have siliconed the grommets in place to keep them from pushing through. Not all lubricants are good for the location of those grommets due to the high heat and can dry them out and they start to shread....spit work well....nojoke
+1 on using spit to lube the 3 posts that hold those removable covers on. If they're deteriorating, then someone used a reactive lubricant that wasn't suitable for those. It may be best to replace those three rubber grommets with any new cover.
:agree: totally.
You’re right about spit. That’s what my dealer recommended. SilverFox
Others have mentioned Windex.
The point is it should be water-based so that it doesn't chemically react with the rubber and it evaporates so it doesn't leave a slippery surface.
I keep a package of spares on the bike. They come two to a pack. I'm on my 3rd pack this year. Used one set myself and lent another to a fellow rider in need. Have the 3rd pack ready to go when needed.....
Package of spare grommets? Is that what you mean? Where do you get them?
Rubber Grommets AKA Oval Washer P/N 705000321 Cheap Cycle parts sells 4 packs. Same Grommets used on all years of all Spyders
Strangely enough, you can find that same part for SeaDoo's, and Outlander and Renegade ATV's though they get progressively more expensive.
Good to know. Local stealer sells 2 pack for 12 bucks+.....:banghead:
The problem with that is if it stays on the grommet then just the way the grease makes it easier to push the pins through, rough riding or whatever makes it easier for the panels to fall off. That's why you want to use spit or Windex or similar. The pins go in easy, then when everything dries out, the come out hard. Those panels have fallen off some machines!
The best thing about this product it dries and eventually washes away. Been using it on the grommets and other things for a while now and no problems.
