DR Buck
I've been trying to resolve the right side heat problem on my RT Limited. I've already installed the Spyderpops top blocking plate and removed the bottom splash plate. Then before going on my road trip last weekend I cut a large oval shaped opening in the inner panel behind the radiator fan (swoop area) and made a temporary blocking plate with some aluminum flashing to close the lower vent as well. This worked great! With the new blocking plate and Spyderpops CAT shields installed almost all of the heat is channeled under the bike and out the back. I'm no longer getting heat up around the seat and the "hot foot" syndrome is gone. The bike temperature stayed in the normal range when it hit 90º and was way down low when it was only 65º.
I was able to have my feet on the riders footrest or the NBV highway pegs without any heat issues during the 400 mile trip. Now I need to come up with a more permanent solution for the aluminum flashing.
EDIT: Looks like the Spyderpops lower blocking plate will be the permanent solution. I just placed the order.
