Been to the post about bleeding and some have said they did it. The manual says to put clear plastic lines on the bleeders, then put fluid into the clear lines, then slowly push down and slowly let up till the line is bubble clear. About 25 times. So does that mean you have to open the valve while peddle is compressed and not close it on release? But then later it says after all bubbles are gone compress peddle open valve then close it before releasing it. Also it says not to use an impact wrench on the lug nuts, but I read an how to video that the guy shows he is using said wrench. Which is correct and also what is the torque of lug bolts? Thanks for any help.
