Blank screen after swith off
agedbikeman
RT 2014 turned key off and went away, when I returned the screen was lit up but blank, plain white and the left handlebar switches were also lit up. Turned key on, blank lit screen went out and usual safety card message appeared but I could start engine without pressing mode and drive of with safety message screen still showing, press mode, all returns to normal drives fine.
Turn key off, same scenario starts all over again, checked error codes got U0155.
Thought, last thing I touched this afternoon I fitted LED light chasers to the rear turn signals, but no problem with turn signals but anyway did a turn signal reset and BINGO cured the problem. Turned key on and off several times, started engine, definatelely cured, error code gone.
Hope this helps someone else.
Thanks Guys, all my efforts to cure this problem were learnt from this site.
