Better garage lighting
T8 bulbs
will T8 bulbs work in older T12 fixtures? they seem to be the highest output, lumen -wise.
I'd look at adding fixtures rather than trying to maximize the output of the existing ones. Remember that the available light falls off as the square of the distance away. More fixtures over a wider area is better than stronger fixtures at one point. Recommended standards for workshops range from 56 lumens (~4 watts) per sq. ft for brightly colored walls and ceilings to 84 lumens (~6 watts) per sq. ft. for dark colored walls/ceilings. Look at your fixtures and go from there...and remember that the light output drops as the bulbs age.
adding two
i think i'm going to add two 4 ' fixtures, that will be front, rear, left side, right side. also some kind of white ceiling. now, what kind of bulbs to use ?
In my 900sqft workshop I have 4 twin lamp 8' florescent lights,plenty of light and I find the 8' tubes are easier to change with just one pin on each end there is no twisting to get them in or out.
Use T5 or T8 florescent bulbs. Do not use T12 bulbs or your fixtures will soon be obsolete. Make certain your new fixtures use electronic ballasts and not magnetic ballasts.
Consider LED lamps as well, they're more expensive up front but will save you money in the long run.
adding two
i'm going to add two fixtures, one of which i have, one i will buy. i'll see how they do, and probably upgrade the bulbs to T8 's. i will add some white ceiling too.:thumbup: thanks to all for the help, and ideas.:bowdown:
WHAT A DIFFERENCE
i switched out one pair of the old T 12 flourecent bulbs for two T 8 6500 k bulbs. the difference is amazing.
i really wasn't expecting that. easily 50 % brighter. i also sprayed the reflectors with chrome ( silver ) paint.
i was sceptical, but now i believe. much more light for less power. i recomend everybody do this:thumbup: at 8 bucks a pair, it's money well spent.
