BEST WAY TO REMOVE WHEEL WEIGHTS?
JKMSPYDER
I received my front wheel balancers from Lamonster Garage yesterday and am anxious to put them on. But I have to remove the weights from the rims first. What is the best way to do that without scratching the rims? A particular solvent maybe? Hammer and chisel?:yikes:
REMOVAL
Well you can start by spraying them with WD-40 and let them sit overnight ...... then if you have a piece of hard wood make a chisel and use that to scrape them off ..... If you lay the wheel down and pry the weights up even a little and spray the wd-40 in the space it will work lots better .............. jmho .... Mike :thumbup:
Border Rider
I use a citrus spray for removing gum and glue. It really works well on double sided tape that most wheel weights have.
I used a plastic scraper to remove and then soak them WD40, goop gone, or brake cleaner. I used brake cleaner to remove the glue. But soaking over night would be better.
David
Like Bluenight911 said WD40 works well, and if you do not want to make a wood scraper you can purchase a plastic one at most places that sell paint.
:agree::agree:This is what I have done to remove tape weights from all of my aluminum wheels. It is slow and a bit of work but, the WD-40 works as a solvent for the adhesive and helps prevent scratches on the rim.
Wheel Balancers
Yesterday I removed the wheel weights by using solvent as others suggested. Installed the Centramatic wheel Balancers on the front wheels and took the Spyder for a spin. I didn't get to ride long as it started raining but I could immediately tell the difference. Very smooth ride. I highly recommend them!
