Best way to preserve front shock mount bottoms?
Best to just not look at them. They will corrode if you ride in rain on roads that had been salted in the past. I always hose off my RS after a messy ride before putting it to sleep in the garage. You could use some spray silicone, but it will not last and could get on the tires.
Nothing. I wouldn't even spray them with anything as that just makes more of a mess and may actually degrade the shock bushing depending what you spray it with.
I suppose you could find some other hardware that was better plated to fasten them with as long at the fasteners were rated the same hardness.
I replaced mine with OEM BRP bolts when I replaced my shocks... and only the shafts had corrosion.
You could try Mercury Corrosion Guard (available at boat stores). However once a year you should remove it and then reapply as it attracts dust and will look dull. It does a fantastic job at preventing corrosion though and is very tenacious. It will not degrade rubber.
