Best Shift Point for RSS
xGreenxMeaniex
Hey guys,
I am a newbie to my Spyder and still learning what makes her tick. What would you all consider is the best RPM to shift at? I kinda find myself letting it get into the 5000's before I shift just because it feels like she wants to shift.
I have the SE5 model- semi automatic shift.
Any help would be appreciated :)
Thanks! I was thinking I was right, but was reading some different numbers, and sometimes she sounds pretty angry at me so I know when to paddle up :)
Thankfully this weekend will be nice for riding!
Hey guys,
I assume you are talking upshift and then it is fine anywhere between 4500 to 9000. Never cruise below 3500 except in first gear, but better to make it a habit 4000.
The RS/GS engines are tuned for a higher peak, so feel free to let it sing! 5000 rpm range is a nice place to start looking for the next gear! :thumbup:
Like they said. The sweet spot--IMO--is the place where you get a seamless shift between gears. The 4500 - 5500 will have the seamless spot somewhere in between. The fun part is you get to drive and experiment a little.
What all the wise men above said. Comfortable RS riding = 4500 - 5500 rpm. Spirited RS riding = whatever the heck I want :doorag:
I think I hit redline only once just to see how the limiter feels when it kicks in so I'm no longer surprised. But usually if I'm really wringing out the bike in the twisties, I'm routinely shifting north of 6 or 7K RPM.
You've got a LOT of power high up in that RPM range that all comes free with your Spyder purchase, it's a darn shame to waste it. If you're baby-shifting the Rotax all the time, you're only riding half of your bike.
I have yet to get this thing out of second gear riding around town....it's too long legged to get into third! If I hit 6th on the highway, I know I'm WELL over the speed limit. :cheers:
Heeeeey! How did you get one with a 6th gear? Was it special order or something? :joke:
I feed it unicorn milk. Makes it do all kinds of crazy things. :doorag: :yikes: I keep referring it to 6 speed... I have to get used to the fact the one gear is reverse...unlike my dirt bike.:gaah:
Sounds..!!
Started out with the crowd but have found the sweet sound at which point I shift. 6000 /7000 rpm's but around town find myself much lower...?:dontknow:
This is an interesting topic. When I bought our RT Limited last Aug, I specifically asked the salesman while test driving. What RPM should I shift at? Knowing I had ridden all variety of 2 wheel bikes, He looked kind of dumbfounded and replied: "Well, what ever feels, sounds right." So for the first 600 miles or so I was shifting at lower RPM as if I was on my HD. Thanks to this site, I learned that higher RPM is best for the Spyder. I know BRP engineers, and people frequent this site, and I would like to suggest they teach the dealers the correct RPM to shift so when they inform the customer, they have the correct info. Also I suggest they revise the manual to instruct the user to shift at higher RPM in a section other than training / safety section where it shows not to exceed I believe it was 2,000 RPM for safety reasons during the getting to know your Spyder.
I now shift at about 4,500 RPM or even higher if conditions are such that I may need extra power such as a hill coming up, or may need to pass another vehicle.
Personally I think you should be hitting the rev-limiter in all five gears :yikes::roflblack::roflblack::roflblack::roflblack:
I usually cruise at around 4500-5000, and on the hills I drop it down a gear (and occasionally twist the throttle a bit too much :opps:)
Just sayin'............
Hey guys,
Maybe this link will help provide you a starting-point to consider shifting...
Good luck on your new ride and enjoy! http://www.spyderlovers.com/forums/s...-Spyder-owners
if you follow some bikers with a normal Speed (65 mph) .. you will find out that the engine needs RPMs to produce the power you neeed - made a test-Video for myselve to find out what gears I use and on what RPMs I change the gears ..(its not good for the clutch if you drive with low RPMs)
