Best flat repair kit is a cell phone and a Mastercard.
You can add AAA to that also.
Stop and go plug kit with CO2 cartridges. Takes up NO room. Thank goodness we haven't had to use it yet .
I agree " thank goodness we haven't had to use it yet " ….. because it doesn't workhyea: …. I just tried to fix a flat in a trailer tire ….FAILED … I would love to see a video of this thing ACTUALLY being used ….. Take yours out and look at it ….. There is no way their rubber plug is going thru that Nozzle …… Try it yourself ...get an old tire ( we all have one or more ) drill a hole in it and try to insert their plug using their instructions …. Please let us know if it worked …. Thanks … Mike
hyea:
I'll go take a look right now-------
Well Mike,
Maybe you saw an older kit. I tried the plug system and it will work-- pushing the mushroom ( and lubed) plug into a tire. The modern Stop and Go system forces the plug in with a threaded " injector" and hex wrench ( supplied ). It would be a pain in the back to do it on the side of the road on the rear tire though. Fronts-- not bad.
I would get a new tire ASAP though. nojoke
Mine looks like the one they are currently selling :dontknow: …… I don't plan to use that trailer tire , I bought a new one ….. I congratulate you on your success …. the rod you must screw in to get the PLUG thru the nozzle has too much space around it …. it deformed the plug very badly and it wouldn't go in all the way ….. Mikehyea:
