Firefly
Mine was really bad so I sprayed some of this stuff on the belt and went for a ride to town and back with no squealing. I guess we'll see how long it last.
Ahhhhh-- good idea... I'll give that a shot.:thumbup:
I think that I found it! :thumbup:
For 2011, the drive belt number was 705501154
For 2012, it has been changed to 705501576
I hope that this helps!
I guess mine has the same problem but it's not a constant squeak. Mine is more of a clicking? /ticking? noise that seems like it's only part of each revolution. Crawled under and took a look and the belt is all the way to the inside of the rear pulley and leaving a rubbery deposit against the side . Had dealer look at it and they said it probably needed adjusted but that it's a bear to do. Didn't mention there being any charge . It has been doing it from almost the time I bought it ...2011 Rt , 6200 miles..Guess I better check on a charge before scheduling it , thought it would be a warranty item for adjustment but maybe not .
Just had the belt replaced on our 2010 RT at 31,000 miles.
Dealer says BRP now recommends a new belt at 28,000 miles.
we have to take it back to replace rear wheel bearings, rotate front tires, and another rear tire.
(first rear tire was replaced around 15,000 miles)
also, we're now on our 3rd muffler . . . . first one lost it's paint (dealer replaced-warranty);
the second one blew out a baffle (replaced-warranty).
The part that worries me about any kind of grease or goop is that it will let dirt stick and build up and be like sand paper grinding away at everything plus it will sling off everywhere making a mess mine is only noticeable when rolling around in the shop or rolling to a stop the last 2 mph I can live with thatAhhhhh-- good idea... I'll give that a shot.:thumbup:
Not all RTs make the noise.So will riding in the rain or snow--- but I do both......
Have tried the belt conditioner a few times and it wears off pretty quick and the noise returns.
I'm not getting why the RT makes this noise and the RS doesn't..... strange indeed.
56,000 miles on my RS and never had this noise.
I'm not sure water holds grit and sticks to parts like grease or goop , maybe the 200 lbs diff in weight between rt and rs make the belt protest someSo will riding in the rain or snow--- but I do both......
Took mine in yesterday an the throttle body update an the radio water problem.. While it was there they went ahead an put a little grease on the belt for me free of charge.. It seems to have fixed my problem.. I never heard it on my way home.
What is a Kricket ll ? Thanks. Road RunnerIt is not a 'Bear' to adjust the belt tension or tracking. It just takes a bit of patience and really, not all that much effort.
Clicking/ticking sounds more like a stone or pebble in the belt but regardless, you don't want it running up against the inner rear sprocket flange. It should have just a bit of clearance to the flange. The flange is just there to keep an improperly adjusted belt from running off the sprocket until you can get it adjusted properly.
Get yourself a Kricket II and do it yourself. You'll learn something and you'll save a BUNCH of money. Then, anytime you might need an adjustment in the future you're good to go!
I've been having the squealing sound when first starting out for the past couple of days. All I did was take it by my dealer and they applied the proper lubricant. No charge, took about 5 minutes and I was on my way. Problem fixed.
Chris
