Battery???
tconaagt
Tried to start my RT just now & when I press the starter button I get a "cilck -click" & the gauges all jump???
Dead battery OR??
Thanks for any help.
Need more..!!
how long was it standing..? How old is the battery.? But the above is a good start. Connections and charge. Good luck..!! :thumbup:
Battery & connections OK.
States ABS FAULT ???
Next move??
I know you say battery and connections are OK, But what your describing is the classic sign of a bad cell in the battery......What are the voltage reading of the battery after trying to start the engine not before....?
Next move??
Charge your battery. If it won't take a charge, it probably needs to be replaced. The warnings and faults you receive when the battery is low mean nothing. They are an artifact of the low voltage.
Bad Battery-----Everything was charging to spec.etc.Bad faults do to bad battery.
New battery (seems a bit of short life--2011).always keep my battery on a tender all winter
Got great service from my dealer--ENNS BORTHERS.
Thanks for all the imput guys.
